F200 gear box oil pressure
  • F200 gear box oil pressure
    I was filling up the gear box with new oil with the yamaha hand pump screwed into the four litre container I had the top screw just turned once so I could here the air coming out and when it reached level oil drained out I then went a little further and pushed oil out through the shaft seals .
    I then removed the top screw and let the oil drain and level out .
    My question is in regards to the shaft seals and weather this is a negative thing to do or a postive indicator of the condtion of the seals .?
    The seals where replaced 100 hrs ago .
    Bad idea.
    The seals are not designed to deal with hydralic pressure.
    Fill with the vent plug removed.
    Stanley Islander 19, 2006 Yamaha F150TLRC. Ottawa, Canada
    16' York River, 1986 Yamaha PRO 50.
      incredibly bad idea.
      I have seen propshaft and shift shaft seals physically pushed out by doing that.
      why not simply drain and fill it PER the service and OWNERS manual?
