Gentlemen,
I have the Yamaha Fuel Management Meter (FMM) for two Yamahas 225 FStroke. I need to know how to use the part number 6Y5-85721-F0-00. It is my understanding that I have to cut the W (white) wire that comes from the Yam Speedometer to the FMM and connect it to the signal lead that comes from the NMEA connection on the GPS. I will use a Scotchlok connector to connect both ends.
The questions are:
1- Is the above procedure correct? Cut and connect W to W?
2- I see two additional cables (R,B) on the square plug coming from the Yamaha speedometer. Shall I continue using them with the W input coming from the GPS?
3- Shall I eliminate the W wire that comes from the Yam Speedometer or keep it?
Your advice will be greatly appreciated as usual. joseeruiz@libertypr.net
The questions are:
