Hi I've got a 30hp yam that won't start (no spark)
I tested the voltage from the charge coil (one that powers the CDI) and I was only getting 45 volts from pull starting and 119 Ohm resistance from the charge coil when disconnected ..... The manual says PEAK voltage should be between 175 and 210 volts ..... I can't see the cranking voltage in the manual so I don't know if I should be getting more voltage when cranking out of the charge coil ..... From the manual the Ohms reading from the coil should be between 164 and 210 Ohms but I've got 119 Ohm ....
So should I get more than 45v on pull start cranking ??
Dose this sound like a suspect coil ??
Or Do you know what the minimum voltage that the CDI will run on ??
