I have a 1986 F9.9SJ Yamaha O/B that is truly been a pain in my %#$%....Well here's the story;I got this outboard from another marina because they couldn't get it going....so far I've replaced the two automatic choke diaphams,the charge coil,the pulser coil and the lighting coil....MY problem is that you can crank it up with five pulls on the starter rope then let it warm up to operating temp..give it throttle, then it starts to like bog and will cut off if you don't throttle it back to just above idle...any input from you guys would be greatly appreciated by this old southern boy lost up in North Michigan...oh the carb I'm sure is clean soaked it in carb cleaner for a couple days
F9.9sj blues
