multifunction gauge kit
  • multifunction gauge kit
    I purchased a 6YR-W0035-F0-00 multifunction speedo and tach kit. I did not notice that it was only for motors up to 2004. I have a F115TLRD, a 2005, so the wiring harness doesn't exactly match up. I have been able to get everything working except the oil pressure and water temp. Is there a wiring harness I could buy to fix this problem? I don't want to spend another five hundred for gauges I already have.
    Yes the adapter, 6Y5-85335-00-00 can be mounted at the gauge.
      Sweet. Just ordered it. Thanks A LOT!
        Well, I have to take back my thanks. That adapter did absolutely nothing. Oil and water still do not work on the gauge. There is still a plug from the gauges with no where to plug into the motor.
