Hi, The overheat alarm sounds off at slow idle but goes off when you pick up the idle and have no problem with it when running . Good water flow at tube and water is cold not hot if the motor was hot. Any ideas as to what could cause this to sound off? Any info appreciated.
thanks
thanks
