Cant get gas to engine 9.9 4 srtoke Yahama
  • Cant get gas to engine 9.9 4 srtoke Yahama
    I cannot get gas to engine. Can put some gas in carb and it will run until it runs out of gas. Bought a new primer bulb and hose, dont seem to be pumping ball full of gas. Ball is not full. Need to get gas to engine somehow. Thanks for helping me.
    No gas to Engine
    Even though I am not an expert by no means, I would try the following. This answer is based on past experience.
    1. Appears that you are pumping air.
    2. Check all connections to take to plugs, to engine
    3. Be sure that you have the primer bulb pointing in the correct direction.
    4. Be sure and check the hose connection at the bulb and the entire hose to make sure there is no cracks.
