1989 ELF30 prop install instructions needed
  • 1989 ELF30 prop install instructions needed
    Hi Folks! I have a 1989 Yamaha 30ELF which I am replacing the prop, prop nut, all spacers and cotter key on. Can anyone remind me what the install order is when you start with a completely bare prop shaft?....I believe the order from most inside part of shaft is ......1.) spacer...2.)prop....3.locking spacer....4.thin washer....5. castle nut....6. cotter key....but I can't remember which direction the 1.) spacer goes?....just want to confirm the order of install...thanks!
    Put spacer in prop so you can see which way spacer fits prop before you assemble them all.
