Hi, I have one of my engines a 2003 four stroke 225HP that the overheat alarm turns on after 2 to 3 hours of *****ing in open sea. I turned it off/on for 10-20 seconds and then I continued for more than five hours with no warning alarm or heat indicator in the gauge.
I also had the problem at the dock with the engine cold and I did the same thing turn it off/on and continue for my fishing day. The engine has 500hrs. I changed the impeller using the Yamaha kit and also replaced the thermostats which looked a little bit rusted but they were working ok. The tell tale water stream looks fine. The engines are used in salt water and flushed with fresh water for several minutes after each use.
I have no clue what else to look for and any help will be appreciated.
