Will 2 HPDI 200hp fit a 41" wide transom ?
  • Will 2 HPDI 200hp fit a 41" wide transom ?
    I have a boat that I bought from the US Navy that has a add on outboard bracket. It had two 150hp outboards mounted on the stern. Would two YAMAHA HPDI 200HP outboards fit on a 41" wide transom?
    Dave
    The 200HPDI need to set on 26 inch centers which is the same as 150. It should work ok
      Thanks for the reply. I was wondering what you mean by 26" centers?
      Thank you
      Dave
        i assume he means centerline to centerline. might already be drilled that way from before, simply measure from say,port top left bolt hole to starboard top left bolt hole or find centers of both.
