Most the time the motor starts and runs normal. Every once in a while (and it is happening more often) the motor will fail to start but once it does it runs normal. I have been working on this thing trying to figure out what part needs replacing. And after quite a few test have come to the High Pressure Fuel Pump. When the motor is acting normal and I turn the key to On I hear the pump running. When I am having this problem on the lake and take the cowling off and turn the key to On I do not hear the pump. What could be going out that would sometimes tell the pump to run and other times not tell it to run. Any and all advice welcomed... Also, is this a characteristic of the pump going out?
Jody
Jody
