2002 F100 4 Stroke Water Cooling Problem
  • 2002 F100 4 Stroke Water Cooling Problem
    On Saturday, I fished in the ocean for 7 hours with no motor problems. On Sunday afternoon, I attached my rabbit ears to the cooling water inlet to flush the water cooling system and it appeared that water was getting drawn into the system; however, no water discharged from the discharge pilot hole.
    I removed the cowling, started the engine again with the rabbit ears attached and could feel the block get warmer. I turned off the engine.
    I then connected a garden hose to the flushing device and could feel the water running though the system; however, no water disharged from the discharge pilot hole.
    Before I assume that I need a new water pump, what else should I do or check to see if the cooling system is functioning properly. Thanks for your advice.
    you should really use a bucket as some times you do not get enough water through rabbit ears
