91 F225 Ignition Issue
  • 91 F225 Ignition Issue
    Engine starts right up without fail.
    When under power seems that cylinders 3 & 5 will drop out randomly.
    The WOT will spin 5500 RPM but will drop to 50-5100 RPM.
    At all speeds this will occur, slow at idle speed 1400 drops to 10-1100.
    Totally random when and for how long it occurs.
    What I have done.
    Had my local mechanic take a crack at it. He couldnt figure it out.
    He bought two new ignition coils for 3 & 5. He broke the carbs down to check jets and reported no probs.
    Compression is good on all cylinders.
    He finally said he thought it was the CDI.
    I bought a used CDI and swapped it myself. The engine does the EXACT same thing.
    I check the Pulser coil, charging coil, ignition sensor all resistances read within acceptable ranges.
    Any other ideas would be appreciated.
    Thanks,
    Keith
    How about your fuel?, is it old or fresh?, did you try running on an aux tank?. Could there be a brief starvation for fuel?
    How about voltage?, while running maybe look at the voltage on the dash guages, see if there is a drop while problem occurs.
      what year for sure
      What Year and can you get it hooked up to a computer and check the injectors and coils that would be a start
      they are gas finicky too if it gets dirty there a bear
