[B][/BHow do you adjust carburetor?
Very simple: I explain that when you have multiple carbs your engine, they have to work as well as your accelerate QUAD.
For the 4-cylinder coseguir this you still need to resort to
VACUOMETRO.Este device is going to measure the vacuum that each cylinder.
Of the No. 4 cylinder # 4 is the one that sets the standard to follow.
Quie Vlora tell you that you have the same vacuum in that cylinder
The rest will have to oner.
A sto s called "sync"
You have to take into account to fester do this assumes that
s will put new spark plugs.
The motors are some qe screws remove them and put the adapter to plug the jacks to vacumetro.
Greetings]
YAMAHA F100 LFAR THAT TAKES TURN ADJUSTING SCREW FACTORY MIX?[COLOR="Sienna"][/COLOR]
