ADJUSTMENT PROBLEMS YAMAHA MOTOR F100LTRA Carburetor
  • ADJUSTMENT PROBLEMS YAMAHA MOTOR F100LTRA Carburetor
    [:coI TREATY IS of adjusting carburetors yaah my F100 AET 2002.
    Of a form and manner following:
    And after having put new spark plugs and check that the fuel does not have ninguntipo of perdida.He relizdo THE FOLLOWING steps:
    1 .- With vauum ayua a tester I made the vacuum test, and as follows: The cylinder # # 4 (importate is boss: a 800rpm
    25 shows the engine pressure. (after the cylinders sequentially
    # 1 - # 2 # 3.a the same pressure.
    The twang of mecl what vuetas tego in 2 and 1 / 2.
    This is what I think I went down and subiedo falla.He laps.YAMAHA MOTOR IS REFERRED F100A (F100AET.
    HE PUT THE MIXTURE SCREW IN 3 ROUNDS YME LESS BUT STILL MAKING A JUDGEMENT IN 2000RPM 2600 RPM, BUT TRY TO HAVE MEJORADO.VOY Located in 3 LAP 1 / 4
    Could you tell me TIMING BRINGS FACTORY?ol:
    YAMAHA F100 LFAR THAT TAKES TURN ADJUSTING SCREW FACTORY MIX?[COLOR="Sienna"][/COLOR]
