I am attempting to interface a Vz 200 HPDI 2 (2008) with a lowrance nema 2k system. I have the 2k connetions etc down pat. I do not have CL. But I do have a white 4 plug/ capped, on the starbord side, and the 2 pink wires cut and capped. The white 4 plug has only 2 wires, 1 white- 1 blue. Is this my access point. can't I just connect directly to that rather than add a Command link hub?
any help esp pix if you have made the connections already would be great. I am hesitant to just plug wire that should fit together.
