150 hp yamaha
  • 150 hp yamaha
    I have a 150 hp yamaha 4 stroke 2007 that cuts no.1 and no.2 injektors when i run between 1200rpm and 1700rpm. If i move the throttle all injektors fire. If i bring the refs down to 1700 the problem consist. The same motor only reaches 5000rpm at full refs to the other motor that reaches 5600rpm.
    It probably needs to check with computer diagnostic to see if TPS and all other sensors readings are in range.
