Prop: Alum -> Stainless question F115
  • Prop: Alum -> Stainless question F115
    I was talking to the dealer and the Yamaha rep happened to be there the other day. My F115 has a 17" pitch, 3-blade aluminum prop on it.
    WOT, I get about 5500 RPM in flat water, but I don't see that very often. In the usual swells and chop my main problem is that I could use a little more power right at about where I want to plane off...
    They both said a stainless 15" pitch would probably be a good call. Less flex and more low end.
    Does that make sense? I think that my WOT would go up, possibly too high... is that a problem since I don't run it that high very often? What are the considerations when going from aluminum to stainless? Is 4 bladed even an option... (need to look into that, but I'm assuming 3 blade at this point)
    Thanks for your thoughts in advance.
    Using a prop with less pitch will help increase hole shot and raise WOT rpm's. You can use a four blade prop if you want, they are generally better hole shot but less top speed from the 3 blades.
