I am the original owner of this motor. It is in excllent condition and I have serviced it regularly. It starts and idles fine at the ramp. After running for a while to the first fishing spot, when I pull back to idle, it idles very rough and then cuts off. It will restart, but does the same thing over and over. It runs great at higher RPM's with no skips, etc. If we sit a while and the engine cools, it idles fine again, but once it heats up, it get's rough and cuts off. I have changed the plugs, the fuel-water seperator and fuel filter on the engine.
Any suggestions or possible diagnosis is appreciated.
