I have a '99 Yammie 60hp on a 16' scout. Now, it idles fast at about 1500 RPM and won't get up on plane on the water. I only get about 2000-2500 RPM in gear at full throttle, but if I put it in neutral, it will rev up to 5500 like normal. At first I thought it might have been condensation in the fuel, but after emptying the h2o/fuel separator bowl and replacing the plugs, as well as putting in a new tank of gas, and checking the carbs (looked pristine) it still does the same thing. Like I said, this thing is intermittent, and if I run it long enough it's like something catches and then I'm back to full power. Any thoughts on what might be ailing my little motor? I have been told that the problem is the microcomputer part # 6h285540-10-00 (now superceeded by part -12-00)
Much obliged
Much obliged
