2000 Yam 150 OX66 VST power
  • 2000 Yam 150 OX66 VST power
    a friends 0x66s vst is having intermittent power issues going to vst pump. where does this 12v come from, comp or keyswitch ? are there any connections inbetween ? e checked 10 pin main and was ok.
    now that i rethink the issue he needs to check grounds also.
    JB
    The power comes from the main relay when key is on but the ground comes from ECU, bad grounds is the most common problem with electrical issues.
