tilt switch
  • tilt switch
    recently I put my SEA PRO cc in at the mamaroneck ramp. when I tried to lower my moter with the tilt switch on the throttle NOTHING,after tapping the switch with a screwdriver handle it worked fine. also switch on moter never faltered. anyone have a solution.
    Nates,
    Try squirting the switch with some WD-40 and move it up and down several times - probably won't help, but it's worth a try. Outside of that, you will have to dissassemble the remote control and replace the switch - could be bad wire connection at the switch also.
    Good luck,
    Ken K
