VST Filter Change on 2004 250 hpdi
  • VST Filter Change on 2004 250 hpdi
    I need to order parts to replace my VST filter but I'm not sure what other parts are required besides the Filter Screen (68F-13915-00-00). I've read about replacing the O Ring but do they mean the Gasket (66K-14984-00-00 GASKET, FLOAT CHAMBER). If not, which O Ring part are they referring too? Also, if you have any additional information on this repair job, it would be appreciated.
    Thanks,
    Rob
    66K-14984-00-00 GASKET is actually a O-ring that joins VS tank togather, that should be all you need.
