Yamaha 200hp
  • Yamaha 200hp
    On my sea pro boat. Took it out today and it started fine and then all of a sudden after a little while it stalled. Then turned the key and it just would not start after it stalled that one time. I kept trying and trying by pushing the throttle and putting it on different positions while turning the key but did not do anything except for one time it started but imeadeatly stalled once again. any help would be greatly appreciated. thank you
    pull a plug, check for spark. can be numerous things, generally spark and fuel. post your findings.
      How old is the motor. Carb or EFI? How long did it sit unused before your started having this problem. Does the primer bulb pump up firm?
      Mike
