Last spring we took our boat to the dealer to service the 90hp Yamaha engine after the boat had been unused for a couple of years. They replaced the water pump impeller, adjusted the carb and said that they had tested the engine and it was ready to go.
Last weekend we took the boat out (for the first time since servicing) for a few hours and when we got back, I noticed a bit more noise that I expected in the lower unit while flushing the cooling system. I decided to check the oil in the lower unit and discovered that there was no oil at all, only water in the lower unit!
After draining the water and putting oil in, oil came out of the water intake port a bit before coming out of the oil level screw hole.
I am new to servicing an outboard and have a few questions. First, should the dealer have noticed that there was no oil in the lower unit? Have we done irreparable damage to the lower unit at this point? Why would the oil come out of the water intake? What should I do now?
Any advice you could give is greatly appreciated.
