Last month my 250 HPDI had a complete new power head install effectively making the motor a "series 2" HPDI. However, I did not get the the most important part of this upgrade , the new ECU. Not having the ECU prevents me from using digital gauges such as the command link. Now, since I have to start replacing my gauges I want to do it right the first time. Would replacing the ECU be a plug and play situation ? Can anyone give me the part number for the updated ECU that would work on my 2004 engine ? Would I have to update the wiring harness. Are there digital gauges based on the analog signal available that would give me among other things the true fuel flow mgt and not just a "gas gauge".
The reason I have to start replacing my gauges is because I have a 1998 BassCat Jaguar that is truly incredible. Bad part is, at the time of manufacture Bass Cat used a computerized "super dash". That dash is incredible and way ahead of its time but it isn't supported any longer and the manufacturer quit building it due to cost. Last week I started to loose dash functions so its just a matter of time before it goes out completely. Any help would be greatly appreciated. Thanks
