I have been having a problem with my trim.tilt assembly leaking oil for past 2 seasons. My mechanic told me that the piston shaft has a pit on it, and oil leaks past seal. He said the whole assembly needs to be replaced. I have been adding oil every time I use boat. This last for the day only.
My question, is there a way to replace shaft and seals while motor on boat. I trailer so access no problem, and will this take care of problem? Is this something I can do myself? Also my concern is that if oil is leaking out, water is possible leaking past seal and getting in. If so, can i remove. Is it worth it to replace. Any help, please,
