1990 Yamaha 150
  • 1990 Yamaha 150
    I have replaced the water pump with new kit and did not make note which way rotation and position pump tabs were facing the problem is I am not getting water through to the heads I have checked flow with hose and lower unit removed and water flows through heads. can anyone help me
    Turn the drive shaft clockwise while installing water pump housing over impeller.
