Reluctant starting
  • Reluctant starting
    My Yamaha T9.9 runs ok except it is reluctant to start. I have to remove the
    cover and goose the accelerator linkage to start it.
    Probably needs carb cleaned and primer system checked.
      Same outboard (1999) same problem.
      I use to remove cover and choke the air intake while starting, then it runs OK.
      What do you mean for "primer system checked" ? do you refer to the fuel pump and, in this case, what you suggest to check, given it then works properly ?
      The engine is used rarely, as it is on a sailboat as auxiliary
      Many thanks
      Alberto
        Reluctant starting
        I think he was refering to the Yamaha 'prime start' system found on many of their smaller outboards. It is meant to replace the function of a choke by automatically giving a rich mixture to the carb until the engine warms up and it shuts this enhanced mixture down.
        I wish I had a diagram of how this unit is assembled. I should not have taken it apart when cleaning the carb, and I am afraid I put the few pieces back incorrectly.
          a diagram is available on
          Yamaha Outboard Parts 2000 F9.9MLHY CARBURETOR Diagram
          may be they are referring to item # 23 "6G8-1410A-01-00 STARTER SET" ??
