i have had fit with this motor, the starboard engine runs fine so hooked up its fuel line ,i switched the following parts carbs,fuel pumps,coils,plugs,computer,the port engine still does run right it will run fine as long as you do not try to go above 3600rpm,all the parts put on the starboard engine and it runs fine still any thoughts thanks dave
1997 200hp ox66 carb
