I have a 200 hp yamaha outboard. New lower unit and the engine has ran in the drive way for about 45min total with no problems. No oil pump so I mix the gas at 50:1 exactly with outboard marine oil. I was running the engine normally for about 10 min on the water and at about half throttle when it suddenly shut down. It then would not crank but the flywheel did turn about an inch and seemed to stop dead every time I cranked it. Any ideas?
Is it possible that something is obstructing the flywheel? The engine did not seem hot any there was no smoke or any real strange noises when it stopped.
