motor starts fine and revs well in neutral - but once in gear it will not rev and go - have any ideas - regards
help with 2 stroke 3 cyl autolube 50hp
I do not think so, I do not have one of those but I think that low tank oil level or motor over temp will cause the motor to go into the safe mode. I believe the timing is retarded to limit the RPM and that is easy to check with a timing light
Originally posted by big a View Postmotor starts fine and revs well in neutral - but once in gear it will not rev and go - have any ideas - regards
I will put up with it till pulled out this fall unless a really nice day shows up with little to do Keep us informed if the cleaning helps
Originally posted by 99yam40 View PostDavee3 Running cylinders lean on fuel because of plugged carbs will cause piston/cylinder damage, fix the motor if it is not running properly
Auto lube should still pull oil? Anyway only run idle speed for a few seconds each start up & at end of trip
Originally posted by Davee3 View PostSounds like my 40 Hp problem - I cleaned the carbs & problem went away for about a day - So this is likely the area to concentrate on . Pretty sure it was the lower carb as I could almost cover the throat without running any different
Now 100% & can idle right down better than ever
