command link part numbers
  • command link part numbers
    I can't seem to be able to find part numbers for the below.
    Sounds like it's not getting any data signal from engine, not easy to test as it is a digital signal. May have bad hub, wire harness or end resistor cap.
    hub
    wire harness
    end resistor caps
    6Y8-81920-01-00 Multi-Hub w/resistor
    Main Bus Wires
    6Y8-82553-41-00 30 ft, 9.1 m
    6Y8-82553-31-00 25 ft, 7.6 m
    6Y8-82553-21-00 20 ft, 6.1 m
    6Y8-82553-11-00 15 ft, 4.6 m
    6Y8-82553-50-00 10 ft, 3.0 m
    6Y8-82553-01-00 1 ft, 0.3 m
    Pigtail Bus Wires
    6Y8-82521-51-00 12 ft, 3.6 m
    6Y8-82521-41-00 9 ft, 2.7 m
    6Y8-82521-31-00 6 ft, 1.8 m
    6Y8-82521-21-00 3 ft, 0.9 m
    6Y8-82521-11-00 2 ft, 0.6 m
    6Y8-82521-01-00 1 ft, 0.3 m
    6Y8-83553-01-00 Power Supply Wire With 10 amps fuse
