I have twin 150 HPDI's with fuel management guages. Evidently only (1) is registering. How can I tell which one is working? Also, I am having a fuel "starving" situation where the primer bulb gets sucked flat on one engine. Is the fuel management sending valve capable of failing and causing this?
fuel management
Regulator,
I don't know how your fuel management system is set up - is there only one feed line coming out of the fuel tank to the management valve?
If there are two feed lines, one for each outboard, then I would check the anti-siphon valve that is hooked to the fuel line right at the tank (if yours has one/two). These anti-siphon valves are bad about plugging up, and the end result is a collapsed bulb and fuel starvation.
Good luck,
Ken K
ÂÂÂ
