2003 90hp power trim problem
  • 2003 90hp power trim problem
    My problem is with the power trim, I have an intermittant short when on the water, the motor only has 53 hours on it, I can't get the problem to show in my driveway. The fuse blew 4 times last time I was out, luckily I was prepared for it as the fuse also runs the starter. I've jiggled wires while raising and lowering the motor, not sure where to start. probably the throttle. Are there any others who have had this trouble? It is too dangerous to take it on the river without a sure fix. I was informed of the problem from the previous owner, but didn't have a problem when test driving it on the lake.
    Make sure battery cable connections are clean and tight.
