I'm using an aftermarket Water Temp Gauge (Teleflex) in my Century Boat. I run a Yamaha C150 with the standard Yamaha 2-wire water temp sender which will not work with after market water temp gauges. Aftermarket temp senders won't work with the Yamaha engine because they are tapered NPT and the engine port for the temp sender is not NPT. Does anyone know of a contact type temp sender unit available which can be attached to the engine heads? I've seen pictures of them but can't find them in any marine catalogs or websites.
