My 225 has been sitting for a very long time (over 2 years).. I've drained all the fuel and changed the gear oil in the LU, new water pump, thermostats, head gaskets, head cover gaskets, water pump, plunger & spring..
It starts and idles fine but will does not run well (under 2K RPM's) under load. Does not idle smooth in the water either. Thinking it's maybe a fuel delivery issue.. All fuel filters were changed too. How can you check a fuel pump? I have a fuel pressure guage.. Are they hard to rebuild or just replace? What about the carbs?
Thanks,
F
Thanks,
F
