Strange grease/oil appearing
  • Strange grease/oil appearing
    I have a 1996 c115 Yamaha outboard. After using for a day some strange thick grease appears on the intake behind the top carberator. I clean it off and it comes back again after the next run. Any common problem that this might be from? Thank you
    Only grease on top of engine is the grease around spark advance plate, may be melting and running down.
