Having a problem with my 02 40. It starts and idles fine but at wide open it dies out. When it dies, the primer bulb is no longer pressurized and you can squeeze the bulb but it won't fill back up at all, not even with air. What would cause this to happen? The motor is obviously pumping gas, it's sucking the primer bulb in but then dies when it runs out in the bulb. It's not a consistent problem, it did it when I got to the lake last night twice, but when I headed back to the launch it ran fine, although I was at slower speeds(Lower RPM). Any Ideas?
Fuel delivery problem
