Get the boat out running again. Ran good 1'day the second time I took it out after about a hour it staited surging again. Limping around on my way in the inlet i couldn't get one of the engines over 1800 rpm with out it cutting out the other engine ran fine. I get home pull the water sep filter and it was only half full of gas. It would run all day not miss or surge at 1500 as soon as i try and give it anymore fuel it falls back down. I would think the fuel pump would put out enough pressure all the time if it was going out it would just go out. Any ideas I think either the fuel line is restricted pump is bad or a bad water sep filter. I changed it 2 trips ago
Half full water sep
