T/T level ?
  • T/T level ?
    can someone explain to me the correct procedure to check for proper oil level and oil type for the trim tilt unit on my 1988 70 hp yamaha outboard (70ETLF) it has a small leak on one of the ram seals.. thanks
    Oil level should be level full at fill plug hole with motor tilted up fully. Use Yamaha Power trim fluid or Dextron II ATF.
