704 control help
  • 704 control help
    Will controls for 1997 40hp C40TLRV work with a 1985 70ETLK? Controls and wiring harness?
    Yes it will work, check that the throttle cable on 40 pushes when throttle increases, if it does then would need to reverse throttle arm inside 704 control box as the 70 requires a pull to open throttle.
      704 control
      Thanks much!
