Yamaha HPDI Wiring Problem
  • Yamaha HPDI Wiring Problem
    Hi, I am really hoping someone can help me with this or point me in the right direction to find someone who knows something about this. I have a 2001 Yamaha Z150txrz outboard. The boat was in a wreck and some of the wires going to the ecu were cut. I bought a factory yamaha service manual to get the wiring diagram. I have been doing continuity tests figuring out which wire is which and have soldered most all the wires back together. I am down to 8 wires and I need to know what pin in the ecu controls what sensor. The manual shows what color goes to what pin bu does not show what that pin controls. Is there anyway to get a breakdown of the ecu pins? Any help you could give me would be great. Thanks
    The wiring diagram in manual will show wire colors at each sensor to be able to trace back to ECU.
