yamaha 25 hp cv choke parts
  • yamaha 25 hp cv choke parts
    i have a 25 hp cv single carb 2000 model outboard and i cant locate a choke part. the part is a small black plastic piece that fits on a small shaft that operates the butterfly on the carb .its part of the choke mechanism. it sits at the end of a small metal rod.its not part of any parts list the piece on the parts list is not the black plastic piece that mounts directly to thr butterfly shaft. the out board workshop in forster say that its part of the carb and i will have to buy a whole new carb, no thank .can any one help
    Is the model number 25CV?
      choke parts
      the model is a 25 hp cv 2000. the model number is i think 61RKS000624 OR 61RK5000624 and its not the rod or the white plastic piece on the end, its the black plastic bit that fits on the end of the white plastic bit, thanks for any help.
        Not familiar with that model and not sure it would be similiar to any US models.
          correct model number
          i wnt and checked the correct numbers are MODEL 25BMHS CODE 61RK AND SERIAL NUMBER 000624 thanks again for any help.
