Rigging for F70LA - almost ready to order!
  • Rigging for F70LA - almost ready to order!
    I am getting ready to place a boats.net order to rig the F70 I am in the process of buying. Thanks to your previous help, I am going to go with:
    Premium Flush Mount Side Control 6X0-48206-12-00
    Command Link Square Tach 6Y8-8350T-01-00
    Single Main and Stop Switch on Panel 704-82570-08-00
    10P Wire Harness 16 ft 6X3-8258A-00-00
    Cables, 7 ft MAR-CABLE-07-SC
    and save a chunk of change over retail prices.
    My remaining questions are on the wiring - does the 10P Wire Harness have everything I need to connect the motor, controls, switch, and tach? Or do I need additional connecting pieces? Does the harness come in different lengths?
    Also, should I be getting the Yamaha rigging tube to let me plug the tube right into the motor cowling?
    I do know I'll need battery cables but I'll worry about that later. Thanks!
    Tim
    Need to order Command Link Tach kit, part number 6Y8-WE83S-70-00, instead of just the tach only 6Y8-8350T-01-00.
    In addition to the kit would also need a main bus wire to go between CL hub at transom and CL hub at console,
    1 FT 6Y8-82553-01-00
    10 FT 6Y8-82553-50-00
    15 FT 6Y8-82553-11-00
    20 FT 6Y8-82553-21-00
    25 FT 6Y8-82553-31-00
    30 FT 6Y8-82553-41-00
