have problem with counter rotating motor kicking water back up on transom and into boat @ all speeds. motor and prop are left hand. 2003 250 hpdi.
single application counter rotating problem
sounds like you may have motor to low on transom?................................. i guess you have lh prop on motor not trying to be a smart ass just asking ........ hell i have done some strange things ........................none that i will probably own up too
will test today. no matter how it was tilted or started, kicked up water @ all speeds onto transom and into boat. motor does push boat over 40 mph.
i put the motor on and it is the correct shaft link for the privateer boat. prop moves the boat forward but kicks quite a bit of water backwards up the transom.
thank you very much, i will try lifting it 2 holes. this forum is a life saver and money saver for me
ÂÂÂÂÂÂÂ
