i'm in a quandry..here is the situation..
1999 25mshw motor..
a couple of months back, while on a long run down the lake, the water impeller broke apart and the motor overheated to the point where it shut itself down to low rpm..
there was significant damage to the power head so I replaced the head + gasket and exhaust covers + gaskets..
compression is fine..spark is fine...carburation is fine...there are no water leaks that I can see..all wires are properly connected..but I can't get the motor to run faster than Idle speed..it looks like maybe the timing is not advancing with the throttle, but I am stumped
any suggestions??
1999 25mshw motor..
any suggestions??
