Starting Problem
  • Starting Problem
    I have a 2008, F115, that apparently has a bad connection in the wiring harness. The starter won't energize unless I squeeze connections, and move the harness behind the key switch. Once it starts, it runs fine. Can you tell me which color wires I should track to find the problem?
    Starter circuit is the brown wire.
      Thanks, I appreciate the help.
        One terminal in a plug was bad. Thanks for the help---saved me a lot of time.
