Pro V 150 problem
  • Pro V 150 problem
    Motor runs great at idle up to around 3000 rpm, after that it starts surging. RPM's have dropped. (4000-4400 from usual 5000) Changed out fuel in tank, checked siphon tube and found no problems, screen filter not dirty at all, replaced the connection from the fuel line to the motor due to some wear on the sealing grommet, no change, new plugs, even added a new clear inline filter. Replaced the hose clamps at all connections No changes. The only thing left to change on the fuel side is the hose and primer bulb but when I checked them they produced plenty of fuel when the primer bulb was squeezed. Motor has worked flawless all spring until now. Ran great the night before. What next? Electrical?
    clean carbs and check fuel pump diaphrams.if its the older model, rid of the quick disconnect fuel line at motor and run direct. what year is it?
      jb123. The motor is a 1989 model.
        i have an 89 on my ski boat,had it for 10 years and i loove it
