Engine was dying on idle & coming off idle after working fine just before Runs fine full & part throttle . Raised idle setting & problem not so bad but sounds like only 2 cylinders operating . My plan run for a while at new idle , stop & pull plugs to see if defective cylinder can be ID'd. Then clean the low speed jet & bowl Question are low speed jets the problem & are they located in bowl Carbs are Keihin . Other suggestions?
40T 2 stroke carb issue
